LPC55S69 Secure Fault Handling
1,928 次查看
__marvin__
I'm currently encountering a problem with secure fault handling and semihosting on LPC55S69.
I'm basically trying to access the secure memory (SECURE_CODE_START) directly in order to generate a SecureFault and analyze it afterwards.
First of all, I was wondering why an occouring SecureFault seems to trigger a HardFault and is not being handled by the SecureFaultHandler routine. (Please correct me in case I'm wrong)
When overwriting the HardFaultHandler as it is given in the LPC55S69 example (SECURE_FAULT_S/NS), my code stops working when not under an active debug section. I assume that there is something messed up with the semihosting, which has been handled by the previous HardFaultHandler.
Thanks a lot && all the best,
__marvin__
1,917 次查看
Helllo marvin,
Yes,  the SecureFault has been handled by the previous HardFaultHandler, because HardFault has higher priority than any exception.  About detail, you can have a look at  ARM Cortex-M33 User Guide:
https://developer.arm.com/documentation/100235/latest
Alice
1,905 次查看
__marvin__
Hi Alice,
thanks for pointing me in the right direction.
Best,
marvin
