LPC55S69 ISP下载
Search instead for
LPC55S69 ISP下载
haifeng_jin
hi  我在用NXP的LPC55S69的时候需要通过USB下载,但是在demo板上发现下载完了,没什么反应,应该是没有成功,工程是通过keil编译出来的gpio例程
mark2
Please use *.bin file with write-memory command.
If you want to use *.hex file, then use flash-image command.
Sabina_Bruce
My name is Sabina and I would be more than happy to assist you. Could you please write you question in english to better understand what you need?
Thank you in advance!
Sabina
haifeng_jin
Download via USB ISP, use blhost tool, but failed
Sabina_Bruce
Are you using USB 0 or USB1 for ISP mode?
BR,
Sabina
