LPC55S69-EVK Simultaneous USB Host and Device
1,024 次查看
ja2022
I have a question about this dev board and this microcontroller. What I would like to do, is have both a USB device and a USB host on one microcontroller, acting as a "proxy" for the USB device connected to the board.
The user manual mentions that either port can be configured as a host at once in section 6.1, but nothing on using one as a host and one as a device. Is this a possible thing to do with this platform? If not, where else should I look within NXP microcontrollers?
Thank you!
1,008 次查看
ZhangJennie
HI
Yes you can have both a USB device and a USB host on one microcontroller.
I suggest you setting different task priority on each task when created. You could take keyboard2mouse sdk example as reference.
Hope this helps,
Jun Zhang
