LPC55S28 using UAC2.0 change audio sample rate
243 次查看
PatrickLai
I am testing UAC2.0 with sample code dev_composite_hid_audio_unified_freertos, SDK version is 24.12.00/25.09.00. After directly import the sample code from the SDK, I made the following change, but both the recorder and the speaker cannot work. Please provide some suggestions or solutions. Thanks!
189 次查看
PatrickLai
need to reinstall the driver for the device
190 次查看
PatrickLai
