LPC55S06 EVK VBAT current measure deep power down
alexanderhaenel
Fresh Out Contributor
I powered the LPC55S06 EVK Board from USB Micro B Plug J1.
I loaded the *lpcxpresso55s06_power_manager_lpc* demo.
The SDK is V2.12
I measured the current across the J20 jumpers (VBAT) on the board.
Normal Mode: 28mA
Deep power down mode: 24mA
My Question: why does the current get not lower?
I expect VBAT current must be some uA.
What am I doing wrong?
Thanks for your help.
Hello @alexanderhaenel
From the terminal output, it seems your chip have wakeup, it is should be in active mode (normal mode) .
While I think maybe your board broken, because even though it in active mode, the power consumption is so high. I check on my side, when it in active mode, the Power consumption is 3.76ma:
Alice
alexanderhaenel
Hello Alice,
Thank you for your fast reply.
My mistake, I measure across J22. I wrote erroneously J20.
I know about pull-ups/downs.
My Question: Why is the current so high in deep-power-down mode?
I have measured the consumption of this board, result almost match with Datasheet.
So you need check your code and measure method.
Alice
alexanderhaenel
Hi @Alice_Yang
thank you for your answer.
My question is. What is the consumption value that have you been measured?
Can you measure the consumption in normal and in deep power down mode?
The code is your SDK example: lpcxpresso55s06_power_manager_lpc.
Are newer version available of your example?
We measured the current (VBAT) over the J22 jumper.
Are there other methods for this Eval board?
See your documentation UM11505 LpcExpresso55S06 Development boards.
Below is the result I measured before, while pay attention, I use the demo lpcxpresso55s06_power_manager_lpc,  Did not disable pull-up/pull-down.
LPCxpresso55s06-evk board.
Alice
alexanderhaenel
Hallo @Alice_Yang
Thank you for your support.
I have powered the board over USB. Can this be a problem?
If not maybe my EVK Board is broken.
Or do you have another idea?
Alexander
"I have powered the board over USB. Can this be a problem?"
->> No problem .
Maybe your board broken. You can also re-confirm your measure method is correct.
Please take a picture of your hardware, and also check code run into deep sleep mode, describe your steps more detail.
Alice
alexanderhaenel
Hallo @Alice_Yang
thanks for your answer.
I am on christmas holidays until 4.1.2023.
I will send details after the Chrismasdays.
Alexander
alexanderhaenel
Hello @Alice_Yang
here comes the requested informations:
The picture:
The code to run into deep mode is your SDK example: “power_manager_lpc”
power_magager_lpc.c :line 266:
            case kPmu_Deep_PowerDown: /* Enter deep power down mode. */
                PRINTF("Press any key to confirm to enter the deep power down"
                     "mode and wakeup the device by reset.\r\n\r\n");
                GETCHAR();
#if (defined(FSL_FEATURE_POWERLIB_EXTEND) && FSL_FEATURE_POWERLIB_EXTEND)
                DEMO_PreDeepPowerDown();
                POWER_EnterDeepPowerDown(APP_EXCLUDE_FROM_DEEPPOWERDOWN,
                                         LOWPOWER_SRAMRETCTRL_RETEN_RAMX2 | LOWPOWER_SRAMRETCTRL_RETEN_RAMX3,
                                         WAKEUP_RTC_LITE_ALARM_WAKEUP, 1);
#else
                POWER_EnterDeepPowerDown(APP_EXCLUDE_FROM_DEEPSLEEP);
#endif
                break;
            default:
                break;
No changes have been made.
The terminal output:
BR Alexander
Alice
alexanderhaenel
Hallo @Alice_Yang
I will get a new one and repeat the measurement.
Alexander
J22 can be used to measure VBAT current, please see
https://www.nxp.com.cn/docs/en/user-guide/LPCXpresso55S06UM.pdf
BTW,  Disable as many internal pull-ups and pull-downs on pins as possible.
Alice
