LPC553x PWM1_B3 output missing?
750 次查看
johnvandenhoef
Hi all,
The LPC553x has 24 PWM outputs according the documentation. However output B3 of PWM1 can not be assigned to any output in the pin function table (RM) or in the MCUXpresso Peripheral signals configurator. So only 23 pins. Is this a bug somewhere?
John
725 次查看
_Leo_
Thank you so much for your interest in our products and for using our community.
Indeed, the PWM1_B3 output is not referenced either in the datasheet or in MCUXpresso Config Tools. Thank you for noticing that point, I will report it to the respective department right away. Meanwhile I suggest you use the ones that are described.
Please let me know if you have more questions about it.
Have a nice day!
