LPC546XX CTIMER configuration question
379 次查看
abdel12312
Hello NXP Community,
I'm working with an LPC546xx and need to know if a single CTIMER can simultaneously:
  1. Use channels 0 and 1 for input capture
  2. Use a match register (MR0) for interrupt generation on counter overflow without affecting any pins
My current setup:
  • CTIMER1 channels 0-1: Input capture
  • CTIMER1 channels 2-3: Timeout interrupts
I need to add timer overflow detection using a match register on the same timer. My though was to use Channels 0 or 1 MRs to be able to count number of overflows.
Since MCR (match control), CCR (capture control), and EMR (pin output) are separate registers, I believe they can be configured independently.
Can someone from NXP confirm if using match interrupts alongside input capture is supported?
260 次查看
Habib_MS
Hello @abdel12312, sorry for the late reply.
Yes, you can configure a channel in Input Capture/Match mode and utilize the match register simultaneously. However, the SDK does not provide an example demonstrating both functionalities together. As a reference, you can modify the example named lpcxpresso54628_ctimer_match_interrupt_example, which already includes the match functionality. This thread may also help guide your implementation.
Habib.
261 次查看
Habib_MS
Habib.
%3CLINGO-SUB%20id%3D%22lingo-sub-2172144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC546XX%20CTIMER%20%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20LPC546xx%EF%BC%8C%E9%9C%80%E8%A6%81%E7%9F%A5%E9%81%93%E5%8D%95%E4%B8%AA%20CTIMER%20%E8%83%BD%E5%90%A6%E5%90%8C%E6%97%B6%E5%B7%A5%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E9%80%9A%E9%81%93%200%20%E5%92%8C%201%20%E8%BF%9B%E8%A1%8C%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A8%20(MR0)%20%E5%9C%A8%E8%AE%A1%E6%95%B0%E5%99%A8%E6%BA%A2%E5%87%BA%E6%97%B6%E4%BA%A7%E7%94%9F%E4%B8%AD%E6%96%AD%EF%BC%8C%E8%80%8C%E4%B8%8D%E5%BD%B1%E5%93%8D%E4%BB%BB%E4%BD%95%E5%BC%95%E8%84%9A%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E7%9A%84%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CUL%3E%3CLI%3ECTIMER1%20%E9%80%9A%E9%81%93%200-1%EF%BC%9A%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%3C%2FLI%3E%3CLI%3ECTIMER1%20%E9%80%9A%E9%81%93%202-3%EF%BC%9A%E8%B6%85%E6%97%B6%E4%B8%AD%E6%96%AD%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E5%90%8C%E4%B8%80%E5%AE%9A%E6%97%B6%E5%99%A8%E4%B8%8A%E7%9A%84%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A8%E6%B7%BB%E5%8A%A0%E5%AE%9A%E6%97%B6%E5%99%A8%E6%BA%A2%E5%87%BA%E6%A3%80%E6%B5%8B%E5%8A%9F%E8%83%BD%E3%80%82%E6%88%91%E7%9A%84%E6%83%B3%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%E9%80%9A%E9%81%93%200%20%E6%88%96%201%20MR%20%E6%9D%A5%E8%AE%A1%E7%AE%97%E6%BA%A2%E5%87%BA%E6%AC%A1%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%20MCR%EF%BC%88%E5%8C%B9%E9%85%8D%E6%8E%A7%E5%88%B6%EF%BC%89%E3%80%81CCR%EF%BC%88%E6%8D%95%E8%8E%B7%E6%8E%A7%E5%88%B6%EF%BC%89%E5%92%8C%20EMR%EF%BC%88%E5%BC%95%E8%84%9A%E8%BE%93%E5%87%BA%EF%BC%89%E6%98%AF%E7%8B%AC%E7%AB%8B%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E7%9B%B8%E4%BF%A1%E5%AE%83%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%8B%AC%E7%AB%8B%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E4%BA%BA%E8%83%BD%E7%A1%AE%E8%AE%A4%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E5%9C%A8%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%E7%9A%84%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%E6%AF%94%E8%B5%9B%E4%B8%AD%E6%96%AD%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC546XX%20CTIMER%20configuration%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254989%22%20target%3D%22_blank%22%3E%40abdel12312%3C%2FA%3E%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E6%99%9A%E6%89%8D%E5%9B%9E%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BE%93%E5%85%A5%E6%8D%95%E8%8E%B7%2F%E5%8C%B9%E9%85%8D%E6%A8%A1%E5%BC%8F%E4%B8%8B%E9%85%8D%E7%BD%AE%E9%A2%91%E9%81%93%EF%BC%8C%E5%B9%B6%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8CSDK%20%E5%B9%B6%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E5%90%8C%E6%97%B6%E6%BC%94%E7%A4%BA%E8%BF%99%E4%B8%A4%E7%A7%8D%E5%8A%9F%E8%83%BD%E7%9A%84%E7%A4%BA%E4%BE%8B%E3%80%82%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BF%AE%E6%94%B9%E5%90%8D%E4%B8%BA%20lpcxpresso54628_ctimer_match_interrupt_example%20%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%B7%B2%E7%BB%8F%E5%8C%85%E5%90%AB%E4%BA%86%E5%8C%B9%E9%85%8D%E5%8A%9F%E8%83%BD%E3%80%82%E8%BF%99%E4%B8%AA%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-SDK%2FCTimer-capture-examples-for-LPC54608%2Fm-p%2F819863%22%20target%3D%22_self%22%3E%E4%B8%BB%E9%A2%98%3C%2FA%3E%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%B8%BA%E6%82%A8%E7%9A%84%E5%AE%9E%E6%96%BD%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3CBR%20%2F%3EHabib.%3C%2FP%3E%3C%2FLINGO-BODY%3E
