Hi, Estanislao,
As you know that the LPC ethernet module supports 10/100MBPS, the 100-pin package of the LPC54606 supports RMII 10/100 ENET only. It includes the following Ethernet signals:
ENET_MDC/MDIO
ENET_RxD0/RxD1/Rx_CLK/Rx_DV
ENET_TxD0/TxD1/TxEN
You can select an ethernet PHY which supports RMII protocol
I think you can use the LAN8720A as PHY the same as that of LPC54608-EVK.
Hope it can help you
XiangJun Rong
