LPC5411x I2C issue
LPC5411x I2C issue
1,011 次查看
domneck
I am using LPCXpresso5411x eval kit for my project and trying to interface I2C based sensor.
I am using MCUXpresso SDK example codes and I have just modified the slave address related stuffs. I2C Start sequence is coming properly but when I try to write byte send I am getting 'kStatus_I2C_Nak' error code and in I2C status register bit MSTSTATE is 3.
标记 (1)
908 次查看
kerryzhou
Hi customer,
   Check the I2C bus wave, then check whether the I2C slave(sensor) give ACK?
   If the slave didn't ACK, it means the I2C baudrate or the wave or the data didn't meet the slave demand, you also need to check the slave datasheet.
Wish it helps you!
Kerry
