LPC54113 USB Configure
4,823 次查看
TDC1333
I have to implement code of USB protocol using LPC54113 in MCUxpresso IDE.
Please provide below details,
1. How to configure USB in peripheral in MCUxpresso IDE.
2.sample code for USB.
TDC
5 回复数
4,809 次查看
ZhangJennie
HI TDC1333
Please refer this article
https://community.nxp.com/t5/LPC-Microcontrollers-Knowledge/Using-ConfigTool-to-create-USB-Project-F...
Hope this helps.
Jun Zhang
标记 (2)
4,805 次查看
TDC1333
Hi Zhangjennie,
I read document.In my case USB is not showing in peripheral option available in MCUxpresso.but driver available in SDK manage component.
for detail PFA.
TDC
4,782 次查看
ZhangJennie
LPC54113 peripheral tool doesn't support USB component. I will escalte it as feature request to config tool team if necessary.
Please refer SDK USB demo code for the USB usage.
Jun Zhang
4,773 次查看
TDC1333
I have to send data to PC using USB.It is possible to send data without configure USB peripheral ?.In USB Demo code use USB peripheral for configure.So how to configure USB without peripheral setting?.
Please provide configure sample code?.
TDC
4,747 次查看
ZhangJennie
For your device, as peripheral configuration tool doesn't support USB, we can only refer USB SDK demo code.
Regarding to which demo you should refer to, it depends on what USB class you use. For example, if you want use USB CDC to communication LPC with PC, refer dev_cdc_vcom_bm demo.
Jun Zhang
