LPC51U68 USB Host CDC
1,949 次查看
fusheng_huang
Hi all :
I want to implement usb host cdc function on LPC51U68.
But  I didn't found any example code in 51U68 SDK.
anyone could support me about this ?
I found usb host cdc example in LPC54608 SDK.
Can I use this example in LPC51U68 ? and anything I need to modify ?
1,937 次查看
ZhangJennie
Hi fusheng_huang
LPC51U68 supports USB device interface only. It doesn't support USB host interface.
So there is no USB host example.
Hope this helps,
Jun Zhang
4 回复数
1,539 次查看
wsd
according to an revision of the data sheet and the user manual the controller has a full speed HOST and device USB controller. Is there any way to implement a host device, otherwise the data sheet is very misleading.
1,938 次查看
ZhangJennie
Hi fusheng_huang
Hope this helps,
Jun Zhang
1,931 次查看
fusheng_huang
because I found USB host folder in SDK, I believe....
anyway, thanks for your reply.
1,926 次查看
ZhangJennie
You are welcome!
