Hello guys : )
Been very busy with other things but this is interesting = )
I like hard concurrency but dislikes FPGA:s - I have tested the Zync platform and nearly changed opinion, but that combo too powerful and hungry.
The LPC43XX is a very stong candidate, the only real competitor (my application) in the ARM space might be the Vybrid family. However then you loose on-chip flash.
The Sitara is nice with its micro engine at your finger tips, although I've not programmed that beast yet.
Have a couple of BeagleBone Black in my trash-can if I get very boored = )
I did dead-bug the LPC4337 QFP144 I recently got from NXP and the few things I tested works brilliant.
I work in the Keil tool chain for now.
Like Holger I clearly see a benefit with separated cores, one with real-timey work and the other with the ethernet stack asf.
My initial strategy was the LPC4337/BGA256 (I'd rather go with the BGA100 but theres no MCPWM there).
Now I've wondered if there might be possible to run an advanced PWM on the third core in the LPC4367 chip.
Well see how things pan out.
Thank you for your input = )
/Henrik
