LPC43S70 HSADC THRESHOLD_SEL=1(THR_A) And HSADC MATCH_VALUE=1
2,876件の閲覧回数
robberpen
Want to know the behavior HSADC_DESC_MATCH(0x0) and HSADC_DESC_THRESH_A below example,
As my undestand,
  1. HSADC_DESC_MATCH(0x0) will start simpling imediataly in this case.
  2. and HSADC_DESC_THRESH_A will start simpling at trigger threshold_A.
In this case. which behavior will be higher priority? simpling  imediataly or wait unitl THRSH_A trigger?
Chip_HSADC_SetupDescEntry(LPC_ADCHS, 0, 0, (HSADC_DESC_CH(1) |
HSADC_DESC_BRANCH_NEXT | HSADC_DESC_MATCH(0x1) | HSADC_DESC_THRESH_A |
HSADC_DESC_RESET_TIMER));
2,817件の閲覧回数
xiangjun_rong
I suppose that you misunderstood the threshold_A, it is not a trigger source, it is a compare register, the ADC sample result is compared with the threshold_A register automatically, then update flag or fire interrupt which indicates that the analog signal is below a threshold or above a threshold.
If you set HSADC_DESC_MATCH(0x10), the adchs module has an internal counter, the tick is the ADC clock, after hardware/software trigger, when the counter reaches 16 or 0x10, the ADC will convert, so the ADC conversion rate is Fadc/16.is you set  HSADC_DESC_MATCH(0x00), the ADC will generate a sample for each ADC clock cycle.
Hope it can help you
Xiangjun Rong
4 返答(返信)
2,843件の閲覧回数
xiangjun_rong
Q1)HSADC_DESC_MATCH(0x0)will start sampling immediately in this case.
>>>>>The HSADC_DESC_MATCH(0x0) does not mean that the ADC converter starts-up immediately, the HSADC_DESC_MATCH(0xxx)  can control the ADC sampling time(ADC conversion rate). Setting HSADC_DESC_MATCH(0x00) means that the ADC can get one sample for each ADC clock.
You can use software trigger to start ADC conversion by setting the SW_TRIGGER bit in Trigger register, pls refer to section 48.6.5 Trigger register.
You can use hardware trigger to start ADC conversion by setting the ADCHS_TRIGGER_IN reg, pls refer to section 18.4.25 ADCHS trigger input multiplexer (ADCHS_TRIGGER_IN).
Q2)and HSADC_DESC_THRESH_A will start simpling at trigger threshold_A.
>>>>>DESCRIPTOR0x[THRESHOLD_SEL] selects the ADC result comparsion threshold register, it is NOT related to ADC starting.
XiangJun Rong
2,828件の閲覧回数
robberpen
Hi @xiangjun_rong
I don't quite understand.
Here a case of  both  HSADC_DESC_THRESH_A and HSADC_DESC_MATCH(0x10) set to descriptor.
then  while  threshold_A was trigger at hsadc timer 0x5, what is the timing clock of simpling? clock 0x5, 0x6 or 0x10?
thanks
Peter
2,818件の閲覧回数
xiangjun_rong
Xiangjun Rong
2,812件の閲覧回数
robberpen
Hi xiangjun_rong
thanks for your clarification.
No more question.
%3CLINGO-SUB%20id%3D%22lingo-sub-1936985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC43S70%20HSADC%20THRESHOLD_SEL%3D1(THR_A)%20%E3%81%8A%E3%82%88%E3%81%B3%20HSADC%20MATCH_VALUE%3D1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1936985%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%3CSTRONG%3E%20%E4%BB%A5%E4%B8%8B%E3%81%AE%3C%2FSTRONG%3E%E4%BE%8B%3CSPAN%3E%3CSTRONG%3EHSADC_DESC_THRESH_A%3C%2FSTRONG%3EH%3CSTRONG%3ESADC_DESC_MATCH(0x0)%3C%2FSTRONG%3E%E3%81%A8%26nbsp%3B%3C%2FSPAN%3E%E5%8B%95%E4%BD%9C%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%AB%8B%E5%A0%B4%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%3C%2FP%3E%3COL%3E%3CLI%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81H%3CSTRONG%3ESADC_DESC_MATCH(0x0)%20%3C%2FSTRONG%3E%E3%81%AF%E3%81%99%E3%81%90%E3%81%AB%E5%8D%98%E7%B4%94%E5%8C%96%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%3CSTRONG%3E%E3%80%81HSADC_DESC_THRESH_A%3C%2FSTRONG%3E%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%20threshold_A%E3%81%A7%E5%8D%98%E7%B4%94%E5%8C%96%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%8C%E5%84%AA%E5%85%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3CSTRONG%3E%E3%81%99%E3%81%90%E3%81%AB%E7%B0%A1%E7%B4%A0%E5%8C%96%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%20THRSH_A%E5%BE%85%E3%81%A1%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CBLOCKQUOTE%3E%3CP%3E%3CSPAN%3EChip_HSADC_SetupDescEntry(LPC_ADCHS%2C%200%2C%200%2C%20(HSADC_DESC_CH(1)%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHSADC_DESC_BRANCH_NEXT%20%7CHSADC_DESC_MATCH(0x1)%20%7CHSADC_DESC_THRESH_A%20%7C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHSADC_DESC_RESET_TIMER))%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1938894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC43S70%20HSADC%20THRESHOLD_SEL%3D1(THR_A)%E3%81%8A%E3%82%88%E3%81%B3HSADC%20MATCH_VALUE%3D1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938894%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFxiangjun_rong%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%82%E3%81%86%E7%96%91%E5%95%8F%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1938845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC43S70%20HSADC%20THRESHOLD_SEL%3D1(THR_A)%E3%81%8A%E3%82%88%E3%81%B3HSADC%20MATCH_VALUE%3D1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Ethreshold_A%E3%82%92%E8%AA%A4%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E6%AF%94%E8%BC%83%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81ADC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%ABthreshold_A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%95%E3%82%8C%E3%80%81%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E4%BF%A1%E5%8F%B7%E3%81%8C%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E4%B8%8B%E5%9B%9E%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%83%95%E3%83%A9%E3%82%B0%E3%81%BE%E3%81%9F%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%99%BA%E7%94%9F%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHSADC_DESC_MATCH(0x10)%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81adchs%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AF%E5%86%85%E9%83%A8%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AFADC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%2F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%8C16%E3%81%BE%E3%81%9F%E3%81%AF0x10%E3%81%AB%E9%81%94%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ADC%E3%81%AF%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81ADC%E5%A4%89%E6%8F%9B%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AFFadc%20%2F%2016%E3%81%A7%E3%81%99%E3%80%82HSADC_DESC_MATCH(0x00)%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ADC%E3%81%AF%E5%90%84ADC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A3%E3%83%B3%E3%82%B8%E3%83%A5%E3%83%B3%E3%83%BB%E3%83%AD%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xiangjun_rong_0-1724380546937.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xiangjun_rong_0-1724380546937.png%22%20style%3D%22width%3A%20282px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294885iF06E58595BC269DA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xiangjun_rong_0-1724380546937.png%22%20alt%3D%22xiangjun_rong_0-1724380546937.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1938546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC43S70%20HSADC%20THRESHOLD_SEL%3D1(THR_A)%E3%81%8A%E3%82%88%E3%81%B3HSADC%20MATCH_VALUE%3D1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F26034%22%20target%3D%22_blank%22%3E%40xiangjun_rong%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%3CSTRONG%3EHSADC_DESC_THRESH_A%20%3C%2FSTRONG%3E%E3%81%A8%20%3CSPAN%3E%3CSTRONG%3EHSADC_DESC_MATCH(0x10)%3C%2FSTRONG%3E%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E8%A8%98%E8%BF%B0%E5%AD%90%E3%81%AB%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%A7%E3%81%AF%E3%80%81threshold_A%E3%81%AFHSADC%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%200x5%E3%81%A7%3CSTRONG%3E%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%20%E3%81%8C%E3%80%81%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF0x5%E3%80%810x6%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%820x10%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%84%9F%E8%AC%9D%3CBR%20%2F%3E%E3%83%9A%E3%83%86%E3%83%AD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1937946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ALPC43S70%20HSADC%20THRESHOLD_SEL%3D1(THR_A)%E3%81%8A%E3%82%88%E3%81%B3HSADC%20MATCH_VALUE%3D1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1937946%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EQ1)H%3CSPAN%3ESADC_DESC_MATCH(0x0)%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3BHSADC_DESC_MATCH(0x0)%E3%81%AF%E3%80%81ADC%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%81%8C%E3%81%99%E3%81%90%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81HSADC_DESC_MATCH(0xxx)%E3%81%AFADC%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E6%99%82%E9%96%93(ADC%E5%A4%89%E6%8F%9B%E3%83%AC%E3%83%BC%E3%83%88)%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82HSADC_DESC_MATCH(0x00)%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ADC%E3%81%AFADC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%94%E3%81%A8%E3%81%AB1%E3%81%A4%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AESW_TRIGGER%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81ADC%E5%A4%89%E6%8F%9B%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(pls%E3%81%AF%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B348.6.5%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81ADCHS_TRIGGER_IN%E7%99%BB%E9%8C%B2%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%82%8AADC%E5%A4%89%E6%8F%9B%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(pls%E3%81%AF%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B318.4.25ADCHS%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E5%85%A5%E5%8A%9B%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%83%BC%EF%BC%88ADCHS_TRIGGER_IN)%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EQ2)%E3%81%A8%3CSTRONG%3EHSADC_DESC_THRESH_A%3C%2FSTRONG%3E%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%20threshold_A%E3%81%A7%E5%8D%98%E7%B4%94%E5%8C%96%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3BDESCRIPTOR0x%5BTHRESHOLD_SEL%5D%20%E3%81%AF%20ADC%20%E7%B5%90%E6%9E%9C%E6%AF%94%E8%BC%83%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20ADC%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B7%E3%83%A3%E3%83%B3%E3%82%B8%E3%83%A5%E3%83%B3%E3%83%BB%E3%83%AD%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
