LPC1765 updating image issue
844 次查看
amandachiang
Good day.
I have an issue on updating the image of the LPC1765 On The Air(OTA). Pls help to give some advice if practicable. Thanks.
The SSPO of the LPC1765 have been used for the SD card and SPI flash in TDM. The data for OTA will be uploaded through the GPRS. The operation of OTA will be failed when the SD card have not been removed from our device. Even though we have already pulled high the CS# of the SD(SD card can't work when CS pull high).
Could you help on this. Thank you.
728 次查看
soledad
Hello Amanda,
Please check the below thread and let me know if this helps!
Firmware Over the Air (FOTA) | www.LPCware.com
Sole
