LPC1758 Proper way to disable/re-enable USB endpoint while DMA transfer is queued
793件の閲覧回数
james3434
I am having an issue where if a USB DMA transfer is queued and the endpoint is disabled and then re-enabled (using the SIE interface), the DMA descriptor will be retired but no EOT or Error interrupt will be raised.
Is there way to cancel a DMA transfer without waiting for it to complete?
James
ラベル(2)
0 返答(返信)
