LPC11xx sysTick interrupt priority confusion
lpcware
Content originally posted in LPCWare by corwinb on Mon Mar 04 09:46:47 MST 2013
I would like to set the sysTick interrupt priority as low as possible (largest number, last to be serviced in a pinch).  I use sysTick now and have studied the docs and example code, however, it is still not clear.  For example, I don't see an entry for sysTick interrupt in interrupt sources table in the UM.  The intpriority example does not appear to be any help either.
Any clues?
Thank you in advance.
lpcware
Content originally posted in LPCWare by corwinb on Tue Mar 05 09:58:16 MST 2013
Got it.  I was reading way too much into it.
