LPC11u12 USART inverted bits
1,185 次查看
rudomanenko
Hi everyone ! How can I config usart on lpc11u12 to send/recieve inverted order of bits? I didn't see anything in any register.
标签 (4)
标记 (3)
1,110 次查看
kerryzhou
Hi Anton Rudomanenko,
     The LPC11U12 UART  hardware don't have the inverted order bits function.
     So, if you really need to do the inverted, I suggest you to realize it with the software, take an example:
   Send, the data which you want to send out, do the inverted at first, then put it to the UART send buffer.
   Receive, when you receive the data, then use the software to do the invert function at first, then save that inverted received data to your according storage buffer.
Wish it helps you!
Kerry
