LPC11Cxx CAN error
LPC11Cxx CAN error
961 次查看
leonardoprates
When LPC11C24 CAN BUS receive a fault frame (CRC error for example), I can see the ID and payload data received to see what I'm receiving?
937 次查看
xiangjun_rong
I suppose that you use interrupt mode, if CAN error happens, you can enable the error event to trigger interrupt, in the CAN ISR, you can check the CAN flags, and take action based on the flags.
Hope it can help you
XiangJun Rong
