Hi shauew,
The master mode and the slave mode should be the same.
Your problem should caused by the mode mismatched between the master and slave.
So, when your master use mode 0, slave should also be configured as mode 0, other modes are the same.
Please check the mode in your master and slave again.
Wish it helps you!
If you still have question, please let me know!
Kerry
