Hi Archana Ravindran,
What the problems you are meeting now?
Check the pin waveform with the oscilloscope, whether the wave in these two pin is correct?
If the pin wave is correct, you need to check your software code which communicate with your LCD, it should meet the LCD command demand.
Kerry
