How to use the IAR development LPC2294?
810 次查看
503789404
who have a demo about IAR (LPC2294),i want to use IAR for ARM development LPC2294,but i can't find demo about iAR()LPC2294 on the internet
758 次查看
Alexis_A
Hi 503789404@qq.com‌,
First of all, if you are starting a new development now, I would strongly recommend that you consider using a Cortex-M based MCU - such as the LPC4xxx or LPC54xxx (or a Kinetis MCU or i.MX RT) - rather than the old ARM7 based MCUs in the LPC2xxx family due to this family is not recommended for new designs as you can see in the below link.
https://www.nxp.com/part/LPC2294HBD144?lang=en&lang_cd=en&
However, if you want to develop using LPC2000 you can take a look to the Sample Code Bundle for LPC213X and LPC214X Peripheral from the link below that is compatible with the MCU you're using
https://www.nxp.com/products/processors-and-microcontrollers/arm-based-processors-and-mcus/lpc-corte...
Unfortunately is only available for Keil, sorry for the inconveniences this may cause you.
Alexis Andalon
