How to use external SDRAM memory on the LPC54018?
908 次查看
RodrigoEngComp
I need to use external SDRAM memory instead of internal SRAMX, however, I had no success in this process, could someone help me with this problem?
898 次查看
xiangjun_rong
As you know the LPC54018 does not have on-chip flash, you have to save code in spifi flash, then copy to SDRAM and execute from SDRAM.
I attach an application note an12423.pdf which discusses where/how to initialize SDRAM and MPU so that code can be copied  into SDRAM and execute from it.
.https://www.nxp.com.cn/docs/en/application-note/AN12423.pdf
Hope it can help you
XiangJun Rong
899 次查看
xiangjun_rong
XiangJun Rong
