How to talk to GPIO pins in binary form, LPC824?
1,067 次查看
joren_joly
I was wondering how to do the following: I'm using an LPC824 and I want to write to gpio_1 and to gpio_15 on the same time, what i can do is just use the Chip_GPIO_SetPinstate function and this works, but i would love to do this just binary.
So instead of:     Chip_GPIO_SetPinState(LPC_GPIO_PORT,0,15,true);
                           Chip_GPIO_SetPinState(LPC_GPIO_PORT,0,1,true);
something like:   *LPC_GPIO_PORT->B[0] = 0b1000000000000010;
But this seems to fail, but i cant figure out why...
Thanks in advance!
标记 (2)
1,001 次查看
Sabina_Bruce
Hello Joren,
Can you try to do the hex value for the binary for example LPC_GPIO_PORT->B[0] |= 0b8002;. Check to see if this results different.
Also instead of just using an equal sign, make sure you use |= or & ~(...) depending if you want to turn on or off certain bits so you do not modify any other configurations.
Let me know your results
Sabina
