Can I request for the BSDL file for LPC2368FBD100 with LQFP package?
Welcome to LPCware.com! | www.LPCware.com
The website only provides FPGA Package and I don't need FPGA..
Thanks!
解決済! 解決策の投稿を見る。
Hi Bernie,
After check carefully with our according department, LPC2368FBD100 doesn't have the BSDL file, because LPC2368FBD100 doesn't support the boundary scan.
Wish it helps you!
Jingjing
Hello Kerry,
Customer required BSDL files(Boundary-Scan Description Language) for LPC2368FBD100 and not the ibis model. Could you check whether we have the BSDL file(should be .bdsl).
Appreciate you could find out whether we have this files.
Hi Audrey, @Bernie Cheah
Thank you very much for your remind.
It's really my fault, I was looking in wrong from the lpcware website, it is the IBIS model not BSDL file, sorry for the inconvenience I bring you.
Now, I already check it with our according department, we still don't have the LPC2368FBD100 BSDL file, just have the ibis file.
Jingjing
Hi Bernie,
Wish it helps you!
Jingjing
Hi Bernie,
If the post is answered your question, please click the Correct Answer button to mark it as solved. Thank you!
Kerry
