How to enable function SGPIO to meet SFF-8485 Specification SFF-8485 REV0.7
2,907 次查看
carter_wang
We use chip LPC5526JBD64E to get the status of hard drives from the host via SGPIO.
I was wondering whether the chip supports the SGPIO function?
If the answer is yes, how to enable it?
BR,
carter
2,862 次查看
ZhangJennie
Hi Cater
Here are some  application notes on how to use SGPIO on LPC4300. If source codes exist, they are included in the zip files:
SGPIO on the LPC4300:
https://www.nxp.com/docs/en/application-note/AN11275.zip
Using SGPIO to emulate an SPI master interface:
https://www.nxp.com/docs/en/application-note/AN11210.zip
LPC4300 camera interface design using SGPIO:
https://www.nxp.com/docs/en/application-note/AN11196.zip
SGPIO camera module design using LPC4300:
https://www.nxp.com/docs/en/application-note/AN11343.zip
Implementing a UART using SGPIO on LPC4300:
https://www.nxp.com/docs/en/application-note/AN11351.zip
Hope this helps.
Jun Zhang
7 回复数
2,890 次查看
ZhangJennie
Hi Carter
Please read this application note. this is
https://www.nxp.com.cn/docs/en/application-note/AN12326.pdf
but we don't have qualification of SFF-8485 Specification.
Have a nice day,
Jun Zhang
2,886 次查看
carter_wang
Hi Jun,
Thanks for your information.
However, I am looking forward to Serial General Purpose Input Output(SGPIO), not secure gpio.
BR,
carter
2,878 次查看
ZhangJennie
Hi Cater.
No. LPC55 doesn't support Serial General Purpose Input Output(SGPIO).
our LPC43xx supports Serial GPIO, but LPC55 doesn't.
Hope this helps,
Jun Zhang
2,873 次查看
carter_wang
Hi Jun,
Got it.
I was wondering if you could share the source code of SGPIO with us?
BR,
carter
2,863 次查看
ZhangJennie
Hi Cater
Hope this helps.
Jun Zhang
2,742 次查看
carter_wang
Hi Jun,
I tried to simulate SGPIO slave device via sensing gpio signals by software.
However, it seems impossible.
Am I right?
BR,
carter
2,843 次查看
carter_wang
Hi Jun,
Have a good day~
BR,
carter
