How to connect LPC802/804 using UART with NORA-W256AWS for AWS IoT core?
728 次查看
geb212
I have to connect an LPC802/804 MCU to NORA-W256AWS for connection to AWS IoT Core, the NORA it's connect to AWS with AT commands, MQTT, Endpoint and Certificate, and it's work, but How I can automate this commands from LPC802 for connect NORA to AWS with UART?
标记 (1)
694 次查看
xiangjun_rong
I suppose that you can declare a two dimensional char array like:
char str[5][20] = {
“AT command1”,
“AT command2”,
“AT command3”,
"AT command4”,
“AT command5“
Hope it can help you
XiangJun Rong
