How to change baud rate of CAN in lpcxpresso55s16 zephyr board file
Aravinth1
Hello Everyone !
I'm trying to change the baud rate of CAN controller , but it's not working by default the baud rate is 125kb , if I try to change 1Mbps it's not working but if I downgrade the baud rate let say 100kb or 50kb it's working , I'm sharing the lpc55s16-eval.dtsi file's can 125kb baud rate implementation part, if I try to change the value from 125000 to 1000000 it's not working , I searched on data sheet there is no information about the maximum baud rate of lpcxpresso55s16 , please help me to fix this issue.
Zephyr version : 3.3.99
Board : lpcxpresso55s16
&can0 {
status = "okay";
bus-speed = <125000>;
bus-speed-data = <125000>;
pinctrl-0 = <&pinmux_can0>;
pinctrl-names = "default";
can-transceiver {
max-bitrate= <5000000>;
@zephyr_care
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, but in this case, I suggest public your questions in the Zephyr community. NXP does not have support for Zephyr.
Pavel
Aravinth1
Hello Pavel,
If you're available, could you please support my  issue , I have already raised the question in zephyr community here is a link
Aravinth
Aravinth1
Hello Pavel,
Thanks for your reply, I have already created a discussion in Zephyr git community, I'm sharing the link for your reference.
