How kI2C_TransferDefaultFlag works for I2C?
1,419件の閲覧回数
cavinlong
This is the sample code of the i2c_polling_b2b_master.
I do not understand why to use the TransferDefaultFlag here,as it seems like it will send the start signal again and will have multiple starts here since the line 108 already sent a start signal.
What is the purpose of having the flags here as the parameter?
Thank you in advance.
3 返答(返信)
1,405件の閲覧回数
Pavel_Hernandez
Hello, my name es Pavel and I will be supporting your case, could you tell me what kind of MCU, or board do you have?
Pavel
1,389件の閲覧回数
cavinlong
hi, LP55S28
1,378件の閲覧回数
Pavel_Hernandez
Hello, I reviewed the information about that example, in this case, this function is using one flag to determine if the communication continues or if this needs to be stopped.
Pavel
