Firmware update using A/B Partion in NXP LPC54s018
1,001 次查看
robo_v
We would like to update the micrcontroller firmware. Can we separate the the flash to A& B partion and NXP LPC54s018 can switch Partion A or B for boot?
5 回复数
977 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, tell me more about your application this mean that you already have the bootloader with OTA or not?
If not, the recommendation is using the next one.
MCU Bootloader | NXP Semiconductors
Pavel
969 次查看
robo_v
Using ISP mode we are downloading the secondary bootloader to RAM and then we are updating the fw image to flash. But in this case,
If the update process did
not finish correctly it can be difficult to recover the old image. So we are looking A/B partion approach
948 次查看
Pavel_Hernandez
Hello, just to be clear on what means A/B, are you looking for the OTA process or the recovery image?
Could you elaborate further about?
Pavel
927 次查看
robo_v
Yes Am looking for OTA process of updating the uC firmware. During this process even if it is interrupted or stoped in the middle it should not result in the brick/non-responsive state
907 次查看
Pavel_Hernandez
