Failed to upgrade my application on LPC55S69 EVK in ISP mode
2,424件の閲覧回数
sushmasan
Hello Team,
I am seeing an issue while upgrading the firmware on LPC55s69 evk using flash magic tool.
During verification I am seeing a failure.
Please find the attached snapshots as a reference,
Can someone please let me know, what is going on?
Some additional information,
I even tried flashing using blhost tool, I did a write the firmware to flash and I read from flash that works fine, but after reset I don't see any difference.
Just FYI, I tried flashing "led_blinky" release .hex firmware on to the LPC55S69 EVK.
San
5 返答(返信)
2,389件の閲覧回数
sushmasan
Hello @Alice_Yang ,
I didn't realize I am using an older version of Flash Magic tool. But after upgrading flash magic to a newer version, the firmware upgrade was successful. There are no changes to made to my code apart from installing a new version of flash magic tool.
I even tried with MCUXpresso IDE, now I was able to do the firmware upgrade.
But still there is another issue. I am able to do firmware only the debug version of the firmware, not the release configuration image. Any idea, what might cause that issue?
San
2,377件の閲覧回数
Hello @sushmasan
How did you generate the release version? What errors occurred? Could you please provide a screenshot of the error?
Alice
2,307件の閲覧回数
sushmasan
Hello @Alice_Yang ,
I have generated .hex using the Binutils on the IDE. Looks like only this particular hex file has failed. Where as I have created a new project and built it. Now I am able to upgrade both debug and release configuration images on the LPC55S69 EVK.
Thanks.
San
2,295件の閲覧回数
Hello @sushmasan
Ok, thanks for your sharing.
Alice
2,408件の閲覧回数
Hello @sushmasan
Please convert your led_blinky.hex  to a .bin file.
And  please erase the flash before writing.
Alice
