Emwin runtime orientation
4,026 次查看
iann
Hi all,
I've got a successful implementation of the emwin libraries running on a LPC54608 hooked up to a ST7789 driven display (320x240, 18bits per pixel) working well displaying text and graphics and can set the orientation correctly as desired at compile time, but there's a requirement to change the orientation during running time if the product is tilted.
I've tried using the function, flag=GUI_SetOrientation(GUI_MIRROR_X |GUI_MIRROR_Y);
This is always returning 1 indicating an error.
I've increased the memory set aside from GUI_NUMBYTES 0x8000 to 0x16000 if memory was a problem but the issue remains.
Are there any other areas I should be looking at?
Any help would be greatly appreciated.
Cheers
Ian
标签 (2)
3,964 次查看
Alexis_A
Hello iann‌,
In the EMWIN reference manual mention that the size of your buffer should be according to the next equation:
Virtual xSize * Virtual ySize * BytesPerPixel
So I think the size of GUI_NUMBYTES should be around 0x2A300
Let me know if this helps you.
Alexis Andalon
3,965 次查看
Alexis_A
Hello iann‌,
Alexis Andalon
3,964 次查看
iann
Thanks Alexis,
That is too much sram for the eval board to cope with at the moment so just for a test I reduced the width and height of the lcd defines and I was able to rotate a quarter of the screen. In the final product this shouldn't be a problem as we'll have external sram but I'll look for a better solution.
Kind regards
Ian
3,964 次查看
iann
Since, I've found the driver we're using GUIDRV_FLEXCOLOR supports this directly so the function GUIDRV_FlexColor_SetOrientation can be called instead and doesn't require the extra memory to be allocated.
