Does it work USB ROM API with USB HS on LPC54xxx?
1,344件の閲覧回数
mikebo
I can't find any example with HS USB on LPC54xxx and USB ROM API.
ラベル(3)
タグ(2)
1,274件の閲覧回数
ZhangJennie
HI Mikhail Modin
For LPC54xxx, we only have USB demo code enclosed in MCUXpresso SDK.
https://mcuxpresso.nxp.com/en/builder
By default that USB demo code is for FS USB0. If you need HS USB1, you need enable high speed mode with below code:
/*! @brief LPC USB IP3511 FS instance count */
#define USB_DEVICE_CONFIG_LPCIP3511FS (0U)
/*! @brief LPC USB IP3511 HS instance count */
#define USB_DEVICE_CONFIG_LPCIP3511HS (1U)
rebuild project.
Make sure you have external power supply to the board when use HS USB.
Have a nice day.
Jun Zhang
