DMA_Init() in fsl_dma.c of SDK 2.7.0 for LPC845BREAKOUT
1,325 次查看
1234567890
This is the function:
First action is to get the instance and store it in the variable 'instance'.
Why is this variable not used in line 127 and 132, like it is in line 138?
1,247 次查看
diego_charles
Hi 1234567890
I´ve found   no special reason. You are right pointing out this,   the variable instance could be used again in those lines since the base won't change.
Best regards, Diego.
