Hi,guys,
I'll use the online SDK Builder generate a downloadable SDK archive for use with desktop MCUXpresso Tools, When i select the Developer Environment Settings, i can't select IAR as the Toolchain/IDE, the default is MCUXpression IDE. But I select the different IDE for the SDK archive a few months ago, what's going on here?
l'm looking forward your reply!
Thanks!
Hi, jeremyzhou,
Thank you for your reply. I have try many times. look at the following picture.
Hi Hananh Hannah,
I don't see the picture you mentioned, I think you'd better upload it again.
TIC
Hi Hananh Hannah,
Fig 1 shows how to terminate pins that are not used in the application. In many cases,
unused pins should be connected externally or configured correctly by software to
minimize the overall power consumption of the part.
Unused pins with GPIO function should be configured as outputs set to LOW with their
internal pull-up disabled.
Fig 1
TIC
