I'm using LPC11U68 for my project. When I build my project on MCUXpresso IDE i see the usage of my flash memory. I know that is some MCUs there is given function or macro that gives the flash usage of flash memory.
Is there a same for LPC11U68?
if not how can I calculate the usage of flash memory, in my code? I know the base address of my flash is:
0x0002 0000
Thanks.
解決済! 解決策の投稿を見る。
There is the 'size' utility you can use to calculate the FLASH/RAM size, see
https://mcuoneclipse.com/2017/03/29/mcuxpresso-ide-s-record-intel-hex-and-binary-files/
how it is used in MCUXpresso IDE.
If you want to have more details: https://mcuoneclipse.com/2020/01/10/listing-code-and-data-size-for-all-files-with-the-gnu-size-utili...
Additionally, the MCUXpresso IDE includes a 'image info' view which gives you a lot of details too:
I hope this helps,
Erich
I hope this helps,
Erich
