Hi Alice, thank you for looking into this. This is what lpc845breakout_led_blinky says:
// Reset entry point for your code.
// Sets up a simple runtime environment and initializes the C/C++
// library.
__attribute__ ((section(".after_vectors.reset")))
void ResetISR(void) {
// Disable interrupts
__asm volatile ("cpsid i");
// Enable SRAM clock used by Stack
__asm volatile ("LDR R0, =0x40000220\n\t"
"MOV R1, #56\n\t"
"STR R1, [R0]");
