We are using a voltage divider circuit to the ADC Vref, but seeing a leakage resistance to ground. Is it safe?
lpcware-support
Senior Contributor I
The input impedance of Vref is around 7k Ohms, so this should be taken into consideration when using a voltage divider on this input.
Labels (2)
Tags (2)
