Are there Ethernet bootloaders available for LPC1700 and LPC2300/2400? If so, where can I find it?
1,744 次查看
lpcware-support
Senior Contributor I
Ethernet bootloaders are available as part of the Flash Magic tool ( www.flashmagictool.com). After installing Flash Magic, you can find the bootloader in the Flash Magic\Ethernet Bootloader directory (C:\Program Files (x86)\Flash Magic\Ethernet Bootloader in a Windows x64 environment). An application note is available for download from www.nxp.com/documents/software/AN10744_Ethernet_Bootloader.zip
标签 (3)
标记 (3)
0 回复数
