how to add peripheral drivers to existing project
3,338 次查看
cprogramming
2,851 次查看
ivadorazinova
Hello baldev patel,
please, what peripheral drivers do you have in mind?
KSDK package contains set of peripheral drivers. You can find these drivers under C:\Freescale\KSDK_1.3.0\platform\drivers
KSDK consists of the following runtime software components:
You can test these drivers under concrete board, in case of FRDM-K64F C:\Freescale\KSDK_1.3.0\examples\frdmk64f\driver_examples
or develop your own code based on the demo using KSDK Project Generator Tool​ (for creating KSDK projects or cloning KSDK projects/demos)
New Kinetis SDK Project Generator is available!
For more information about all these drivers please refer to KSDK v.1.3 API Reference Manual
I hope this helps you.
Iva
2,852 次查看
ivadorazinova
Hello baldev patel,
Iva
2,851 次查看
cprogramming
Hello Iva,
I have FRDM-K64F board running myproject with LED flashing. What I would like to do is to add SPI driver to myproject.
I Have tried DSPI Demo on its own on FRDM-K64F  that works ok.
Thank you for your help.
Baldev
2,851 次查看
ivadorazinova
Hello baldev patel,
just include the driver to your project and to compiler settings.
I mean include e.g. #include "fsl_edma_driver.h" in main.c
and have included correct files and paths in compiler settings:
Some useful tips for you:
Iva
