create kinetis SDK 2.x project
3,126 次查看
yiluxiangwan
I am a novice,I use KDS 1.3.
I want create kinetis SDK 2.x project , I don't know where this  SDK 2.0 root folder is .
Help.
5 回复数
2,149 次查看
ivadorazinova
Hello.
Please can you specify your issue?
For downloading KSDK 2.0 is needed to use Welcome to Kinetis Expert | Kinetis Expert
Please take a look at following articles:
How to: install KSDK 2.0
Using Kinetis Design Studio v3.x with Kinetis SDK v2.0
I hope this helps you.
Iva
2,149 次查看
yiluxiangwan
Hi.
This is the case   :  Click  File>>New>>Kinetis SDK 2.x Project , Pop up a name is  Kinetis SDK 2.x project wizard   a window.      Select project name and SDK 2.x Path(root folder).
My problem :   I don't know what SDK 2.x  path is .  I can't search the local document for information about it.
                         Can you tell me how to find the SDK 2.x  path?
Thank.
2,149 次查看
Hello ,
The root folder is the folder you download , for example for the SDK_2.0_FRDM-K64F,
when you download it , it is a compressed files "SDK_2.0_FRDM-K64F.zip", please unzip it , when you create project,
the path is the folder "SDK_2.0_FRDM-K64F" (you can put this folder to anywhere ):
Hope it helps
Alice
2,149 次查看
yiluxiangwan
I'm using K60.Nxp website is no K60 SDK 2.0,only have  SDK_1.3_TWR-K60D100M .  So,I cannot create about K60 kinetis SDK 2.x project.
I think this is the case.
Thank you.
2,149 次查看
ivadorazinova
yes exactly, because K60 is not supported by current KSDK 2.0.
But you can be calm, K60 will be supported in early of May.
Iva
