Hello.
Please can you specify your issue?
For downloading KSDK 2.0 is needed to use Welcome to Kinetis Expert | Kinetis Expert
Please take a look at following articles:
Using Kinetis Design Studio v3.x with Kinetis SDK v2.0
I hope this helps you.
Iva
Hi.
This is the case : Click File>>New>>Kinetis SDK 2.x Project , Pop up a name is Kinetis SDK 2.x project wizard a window. Select project name and SDK 2.x Path(root folder).
My problem : I don't know what SDK 2.x path is . I can't search the local document for information about it.
Can you tell me how to find the SDK 2.x path?
Thank.
Hello ,
The root folder is the folder you download , for example for the SDK_2.0_FRDM-K64F,
when you download it , it is a compressed files "SDK_2.0_FRDM-K64F.zip", please unzip it , when you create project,
the path is the folder "SDK_2.0_FRDM-K64F" (you can put this folder to anywhere ):
Hope it helps
Alice
I'm using K60.Nxp website is no K60 SDK 2.0,only have SDK_1.3_TWR-K60D100M . So,I cannot create about K60 kinetis SDK 2.x project.
I think this is the case.
Thank you.
yes exactly, because K60 is not supported by current KSDK 2.0.
But you can be calm, K60 will be supported in early of May.
Iva
