What is the "Business-friendly licensing model?"
3,354件の閲覧回数
stevesarakas
Doesn't the Kinetis SDK license require the company to turn over the firmware and all the patent rights to their product to nxp Freescale?
3 返答(返信)
2,653件の閲覧回数
stevesarakas
Both the 1.3 SDK builder page and the 2.0 Standalone version download page require agreement with nxp/Freescale license which is not the same as the BSD license. Section 5 specifically states:
Upon request, you must provide Freescale the source code of any derivative of the Licensed Software. You agree to assign all, and hereby do assign all rights, title, and interest to any such modifications to the Licensed Software to Freescale and agree to provide all assistance reasonably requested by Freescale to establish, preserve or enforce such right. Further, you agree to waive all moral rights of approval, restriction, or limitation on use or subsequent modification.
2,653件の閲覧回数
mnorman
Hi, Steve,
The KSDK v2 includes several components, each with their own license.  However, all Freescale/NXP authored content is provided under a BSD 3-Clause license, which is a common, permissive, open source license.  Here are some resources that describe it further:
https://tldrlegal.com/license/bsd-3-clause-license-%28revised%29
The BSD 3-Clause License | Open Source Initiative
All other components are offered under similar open source licenses or evaluation licenses from their authors.
For example, I've pasted the "Software Content Register" for a FRDM-K64F KSDKv2 package, which lists all the software components and their license:.
Release Name: Kinetis So  KSDK_2.0.0_GA_REL1
ftware Development Kit (
SDK) Package - Kinetis S
DK
KSDK Peripheral Drivers    Description: Peripheral drivers are designed for t
                          he most common use cases identified for the underl
                          ying hardware block.
                          Author: Freescale
                          version: 2.x.x
                          License: Open Source - BSD-3-Clause
                          Format: source code
CMSIS Core header files    Description: Industry-standard header files distri
                          butes by ARM for cortex-M cores
                          Author: ARM
                          version: 4.3 (CMSIS Download 4.5)
                          Format: source code
                          URL: http://silver.arm.com
CMSIS DSP Library          Description: A digital signal processing library f
                          or Cortex-M cores from ARM
                          Author: ARM
                          version: 1.4.5 (CMSIS download 4.5)
                          Format: source code
FreeRTOS(tm)              Description: A real-time operating system(RTOS) fr
                          om Real Time Engineers, Ltd.
                          Author: Real Time Engineers, Ltd.
                          version: 8.2.3
                          License: Modified GPLv2. See rtos/freertos/License
                          /license.txt.
                          Format: source code
                          URL: http://www.freertos.org
uC/OS-II(R)                Description: A real-time operating system(RTOS) fr
                          om Micrium
                          Author: Micrium, Inc.
                          version: 2.92.11
                          License: Proprietary. See LA_OPT_Base_License.htm,
                            Appendix A, Micrium.
                          Format: source code
                          URL: http://micrium.com
uC/OS-III(R)              Description: A real-time operating system(RTOS) fr
                          om Micrium
                          version: 3.05.01
                          Format: source code
SD MMC Card middleware    Description: A software componnet support SD card,
                            eMMC card.
                          Author: Freescale
                          version: 2.0.0
                          License: Open Source - BSC-3-Clause
                          Format: source code
MBED TLS stack            Description: Cryptographic and SSL/TLS Library
                          Author: ARM
                          version: 2.1.2
                          License: Apache-2-Clause
                          Format: source code
                          URL: https://tls.mbed.org/
DMA Manager                Description: A software component used for manage
                          on-chip DMA channel resources.
                          Author: Freescale
                          version: 2.0.0
                          Format: source code
USB                        Description: Freescale USB stack. This is a versio
                          n of the USB stack that has been integrated with t
                          he Kinetis SDK.
                          Author: Freescale
                          version: 1.0.0
                          Format: source code
lwIP TCP/IP Stack          Description: A light-weight TCP/IP stack
                          Author: Swedish Institute of Computer Science
                          version: 1.4.1
                          Format: source code
                          URL: http://savannah.nongnu.org/projects/lwip
wolfSSL                    Description: wolfSSL is cryptography and SSL/TLS l
                          ibrary
                          Author: wolfSSL Inc.
                          version: 3.6.8
                          License: 3rd party evaluation. See middleware/wolf
                          ssl_3.6.8/wolfSSL_cyaSSL_evaluation_license_agreem
                          ent.pdf
                          Format: source code
                          URL: https://www.wolfssl.com
mmCAU S/W Library          Description: S/W library that works with the memor
                          y-mapped cryptographic acceleration unit present o
                          n some Kinetis SoCs
                          Author: Freescale
                          version: 2.0.0
                          Format: source code
EMV L1 stack              Description: The EMV (Europay-MasterCard-Visa) L1
                          stack which complies to EMV_v4.3_Book_1 specificat
                          ion.
                          Author: Freescale
                          version: 2.0.0
                          Format: source code
FatFs                      Description: FatFs is a generic FAT file system mo
                          dule for small embedded systems.
                          Author: Electronic Lives Mfg. by ChaN of Ageo city
                          , Japan (hobbyist)
                          version: 0.11a
                          License: Open Source - FatFs License, middleware/f
                          atfs/doc/en/appnote.html
                          Format: source code
                          URL: http://elm-chan.org/fsw/ff/00index_e.html
                          Approved Open Source License: Yes
2,653件の閲覧回数
ivadorazinova
Hi Steve,
thank you for your question.
Please, can you provide to us more details about your problem you face to?
Maybe mnorman could help with the KSDK license and the patent rights and tell more details.
Thank you,
Have a nice day.
Iva
