What is the endiannes of MKE1xF?
jordi_becares
Dear all,
I'm working over MKE18f. When I debugging I can see that the RAM is BIG endian, but instruction code in FLASH is little Endian. Is it correct? I didn't see it before in other MCU.
Jordi
Tags (2)
jingpan
Hi Jordi,
In memory window, endian can be adjusted. Right click the window->endian
You can also select cell size to 1 byte. Then you'll see RAM and Flash has same endian.
Jing
