Hi, Neil,
KSDK v1.3 (latest at the time of this writing) includes several software components, all with individual licensing. The license attributed to each component is outlined in the Software Content Register (SCR) and pasted below. The intention for the peripheral drivers and as much of the software that runs directly on the Freescale hardware is to enable them with very permissive licenses. We chose the BSD 3-Clause license such that the HAL and peripheral drivers could be used by other projects, such as micropython. Note that the KSDK is used today as the lowest layer of the ARM mbed software platform support for Kinetis -- a very similar usage to what is being proposed here.
in summary, you can take any of the BSD licensed software in KSDK and use them in other projects as long as the license requirements (the 3 clauses) are meet. Easy enough!
-Michael
Release Name: Kinetis Version: 1.3.0
Software Development
Kit (SDK)
Package - Kinetis SDK
CMSIS DSP Library Description: A digital signal processing
library for Cortex-M cores from ARM
Version: 1.4.4 (CMSIS download 4.2)
Author: ARM
License: Open Source - BSD-3-Clause
Format: source code
URL: http://silver.arm.com
KSDK_1.3.0/platform/CMSIS/DSP_lib
CMSIS Core header files Description: Industry-standard header files
distributed by ARM for Cortex-M cores
Version: 4.20
Author: ARM
Format: source code
KSDK_1.3.0/platform/CMSIS/Include
USB Description: Freescale USB stack. This is
a version of the USB stack that has been
integrated with the Kinetis SDK.
Author: Freescale
License: Proprietary. See Freescale EULA
LA_OPT_FSL_OPEN_3RD_PARTY_IP, Appendix A,
MQX RTOS Code.
Format: source code
mmCAU S/W Library Description: S/W library that works with the
memory-mapped cryptographic acceleration
unit present on some Kinetis SoCs
Version: 1.3
Author: Freescale
Format: source code
KSDK_1.3.0/platform/drivers/src/mmcau
Flash / NVM Description: Software driver (SSD) for Flash
and EEPROM
Version: 3.4
Author: Freescale
Format: source code
KSDK_1.3.0/platform/drivers/src/flash
Processor Expert (PEx) Description: Processor Expert (PEx) service
Support for KSDK pack with support for KSDK 1.3.0
Author: Freescale
LA_OPT_TOOL
Format: binary
KSDK Peripheral Drivers Description: Peripheral drivers are designed
for the most common use cases identified for
the underlying hardware block.
Version: 1.3.0
Author: Freescale
Format: source code
KSDK H/W Abstraction Description: The HAL abstracts the H/W register
Layer (HAL) access into a set of stateless functional
primitives which provide the building blocks for
peripheral drivers or applications.
Version: 1.3.0
Author: Freescale
Format: source code
lwIP TCP/IP Stack Description: A light-weight TCP/IP stack
Version: 1.4.1
Author: Swedish Institute of Computer Science
Format: source code
URL: http://savannah.nongnu.org/projects/lwip/
FatFs Description: FatFs is a generic FAT file system
module for small embedded systems.
Version: R0.09b
Author: Electronic Lives Mfg. by ChaN of Ageo city,
Japan (hobbyist)
License: Open Source - FatFs License
Approved Open Source License: Yes
Format: source code
URL: http://elm-chan.org/fsw/ff/00index_e.html
Package - FreeRTOS(tm) Description: A real-time operating system
FreeRTOS(tm) (RTOS) from Real Time Engineers, Ltd.
Version: 8.0.0
Author: Real Time Engineers, Ltd.
License: Modified GPLv2. See
KSDK_1.0.0/rtos/FreeRTOS/src/FreeRTOS_license.txt.
Format: source code
URL: http://www.freertos.org
Freescale MQX(tm) kernel Description: A real-time operating system
(RTOS) licensed by Freescale from
ARC/Synopsys. This is a subset of
Freescale MQX that has been integrated with
the Kinetis SDK.
Version: 1.3.0
Author: Freescale
Appendix A, MQX RTOS Code.
Format: source code
uC/OS-II(R) Description: A real-time operating system
(RTOS) from Micrium
Version: 2.92.10
Author: Micrium
Appendix A, Micrium.
Format: source code
URL: http://micrium.com
uC/OS-III(R) Description: A real-time operating system
(RTOS) from Micrium
Version: 3.04.03
Author: Micrium
Format: source code
ISC BIND Description: Reference implementation of
the Domain Name System (DNS) Internet
protocol.
Author: Internet Systems Consortium
License: Open Source - ISC
Format: source code
URL: https://www.isc.org/downloads/bind/
getopt Description: A C function used to parse
command-line options.
Version: n/a
Author: AT&T
License: Public Domain
Format: source code
URL: http://www.informatica.co.cr/unix-source-code/research/1985/1103.html
Freescale MQX(tm) Description: MFS is s FAT12/16/32 file system
MFS file system licensed by Freescale from
the Kinetis SDK.
Version: 1.0.0
Author: Freescale
Format: source code
Freescale MQX(tm) Description: RTCS is real-time TCPIP stack
RTCS stack licensed by Freescale from
the Kinetis SDK.
Version: 1.0.0
Author: Freescale
Format: source code
