Im using SDK 2.0 with a K66 - I cant find a driver for programming SysTick - where can I find it
1,228件の閲覧回数
steverobalino
I only find functions for programming PIT
1,105件の閲覧回数
Jmart
Steve,
The drivers that you see inside of the device folder for your K66 are specific to the SoC and do not contain any special core functionality. The systick is an ARM Cortex-M feature and all register information can be found in the core_cm4.h header file under the <install_dir>/CMSIS/Include folder. The register information for systick begins around line 735.
Jason
