What are those platform files (found in \...\platform\devices) and why don't they have the full MCU number?
If I am using a MK10DN32VFM5 which platform folder should I use?
Does that MK10D10 folder apply to all the K10s?
Where do I find information about this?
解決済! 解決策の投稿を見る。
Hi Jorge,
The platform folder contains the “foundation” of the KSDK, it stores the source code for the primary components including CMSIS header files, peripheral drivers, HAL, OS abstraction, startup, system services and linker files. There is a folder for each of the supported MCU families, not for each part number.
The MK10DN32VFM5 part is not supported by Kinetis SDK, you can find the supported devices on the chapter 4 of the following document:
http://cache.freescale.com/files/soft_dev_tools/doc/support_info/KSDK120RN.pdf
You could use the K11DA5 platform as a base to port the SDK to your device, here is a document that explains how to do this:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Hi Jorge,
Hope it helps!
Carlos Mendoza
Thanks, this has been really helpful. I am beginning to understand how all this works.
