How to get debug prints in the kinetics bootloader.
1,793 次查看
Bhumika
I have implemented bootloader (kinetics bootloader) in KM35 board (TWR-KM35Z75M) and successfully load an application code through UART but not getting any debug prints.
How can i enable debug_prints.
Thanks.
1,723 次查看
Bhumika
i am getting the logs on host application but the bootloader debug prints are not getting on the console how i can enable that for the bootloader?
Also can i initialize another UART instance for prints one for the host application and another for debug prints on the console?
1,695 次查看
xiangjun_rong
The UART port and RX/TX pins the bootloader uses are fixed, user can not change the uart port and pins.
Hope it can help you
XiangJun Rong
1,737 次查看
xiangjun_rong
Pls refer to the application note and check if you can load your application code based on flashloader, uou can use KinetisFlashTool or blhost run on PC.
https://www.nxp.com.cn/docs/en/application-note/AN12888.pdf
XiangJun Rong
