Hello
i'm very new to the Kinetis and KDS, so please be patient with me. I installed the KDS and also the KSDK.
I made 2 different Projects, Project 1 with Kinetis SDK (1.2) and Project 2 without.
In the component library, most of the components are the in both Projectes the same or similar, with the difference that some names of the components form the KSDK start with "fsl_".
What is the main difference between using the components from the KSDK versus using the "standard" Kinetis components form the KDS (or Codewarrior)?
Which sould i use?
Dorian
