Create and generate colors with PWM on KDS 3.0.0 with KSDK 1.3.0 and PE
1,996 次查看
matheusquintili
How i create new color with pwm component on KDS 3.0.0 and KSDK 1.3.0 and PE(or just one of both). And after build a lib with the colors codes)
标记 (1)
5 回复数
1,642 次查看
matheusquintili
Hi Iva,
Im use KDS 3.0.0, and i need to create new colors with PWM, cause i need more colors than the simple colors combination (red+blue+green, red+green, red+blue and blue+green), and after make this colors (about a 15) i need generate a lib for use this colors in other applications
Thank you for help.
Best Regards
Matheus
1,642 次查看
ivadorazinova
Hi Matheus,
please, take a look at this.
Rainbow color using FTM PWM with KSDK 1.3
I hope this is what you found.
Iva
1,642 次查看
ivadorazinova
Hi Matheus,
please, can you take a look at following thread?
Here is the example, which you found.
PWM component in PE for KDS?
I hope this helps.
Iva
1,642 次查看
matheusquintili
Hi Iva,
Thank you for the help, but i see this before and don´t hepls me
1,642 次查看
ivadorazinova
Hi Matheus,
so could you give me more details about your issue?
Thank you.
Iva
