Hi.
Thank you for your help.
Please teach by controlling DC motor with brush.
I heard that if it doesn't work for a long period of time, an oxide film may form on the brush and it may not work.
Please let me know if you know any software or hardware measures.
I am studying with a motor voltage of 6V.
jun
Solved! Go to Solution.
Hello Jun,
Hope you are doing well.
I do not understand your question very well. If you are looking for information on DC motor with brush we do not have a tutorial on how they work. I'd recommend to check other resources for an explanation of the oxide film and what can occur physically to the motor.
A simple guide on brushed DC motor controlled by LPC can be found in this application note. Here you will find some fundamentals of a brushed DC motor, but it does not go into details like the oxide film.
If you need help on how to control a DC motor, please let me know what microcontroller you are using so that I can help you with the correct information.
Hope it helps!
Sabina
Hi.
Thank you very much.
OK.
jun.
Hello Jun,
Hope it helps!
Sabina
